Page 1 of 1
using wapt-exit.exe
Published: April 22, 2020 - 5:34 PM
by olaplanche
I'm following up on the use of wapt-exit.exe.
I've noticed a problem, but I haven't been able to find the cause.
The description is:
wapt-exit.exe doesn't run automatically when the PCs shut down.
wapt-exit.exe runs automatically when the PCs restart.
What I've checked:
Hyperboot is indeed disabled by changing the HyperbootEnabled value to 0 in the registry via a domain GPO.
wapt-exit.exe is present in the local GPO.
In wapt-get.ini:
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
allow_cancel_upgrade=1
Do you have any suggestions?
Thank you
Re: Using wapt-exit.exe
Published: April 22, 2020 - 6:48 PM
by sfonteneau
olaplanche wrote: ↑Apr 22, 2020 - 5:34 PM wapt-exit.exe does not run automatically when PCs are shut down.
wapt-exit.exe runs automatically when PCs are restarted.
I've never actually had that problem; for me, whether it's a restart or a shutdown, the shutdown scripts should work.
Have you tried putting something else in the GPO shutdown scripts?
Published: April 27, 2020 - 09:19
by olaplanche
After various tests, my conclusion is as follows:
There are no issues with wapt-exit.exe; the problem occurs because the Group Policy client stops unexpectedly.
I won't bother you any longer with my problem. :D
Take care.
Published: April 27, 2020 - 10:09 AM
by sfonteneau
No worries, one last possibility: another GPO that might be crashing the entire GPO engine?
Unfortunately, we haven't found any other solution than a GPO to launch a program when the computer shuts down...
If anyone has any ideas
Published: April 27, 2020 - 10:19 AM
by olaplanche
Actually, the Group Policy client service is configured by default to start automatically (trigger startup), which means the service can stop if it's not doing anything, and then a trigger can restart it at any time...
I still need to figure out why it doesn't restart automatically every time I shut down the PC!
Thanks
Published: April 29, 2020 - 2:33 PM
by olaplanche
I need some information:
At home, do you only use the `hiberboot_enabled=0` option in the `wapt-get.ini` file to disable Windows 10 Hyperboot? Nothing in a Group Policy Object (GPO)?
I realize that on my personal PC, where I use WaptStarter, I have the registry key `HKLM\CurrentControlSet\Control\Power\HilbernateEnabled=1` and the `hiberboot_enabled=0` option in the `wapt-get.ini` file, and it works perfectly! If I look in the GUI (Control Panel\All Control Panel Items\Power Options\System Settings), I can see that Fast Startup is disabled!
At work, I have the `HKLM\CurrentControlSet\Control\Power\HilbernateEnabled` registry key set to 0 by a GPO and the `hiberboot_enabled=0` option in the configuration file!
I'm starting to wonder if that's the problem! What exactly does the `hiberboot_enabled=0` option do in the config file? I have a feeling it's not the same thing as the registry key!
Thanks
Published: April 29, 2020 - 4:09 PM
by sfonteneau
You're not looking at the correct registry key:
https://github.com/tranquilit/WAPT/blob ... n.py#L3539
https://github.com/tranquilit/WAPT/blob ... ce.py#L221
or perhaps the key value needs to be changed?
Published: April 29, 2020 - 4:22 PM
by olaplanche
Ah yes, :mrgreen:
I got confused when manually checking the registry...
But I do have the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Power\HiberbootEnabled key set to 0 by the GPO.
So the hiberboot_enabled=0 option in the config file does the same thing as the GPO...
So it all fits together, everything's fine on that end, darn...
Thanks!
Published: April 29, 2020 - 4:34 PM
by sfonteneau
When you say personal PC, do you mean a home Windows installation?
Published: April 29, 2020 - 4:48 PM
by olaplanche
No, it's a Windows 10 Enterprise :lol:
