Page 1 of 2
[SOLVED] [Chrome] Update 81.0.4044.129 that won't install
Published: April 29, 2020 - 10:51 AM
by benoitpatin
I updated my Google Chrome package via the Tranquil IT repositories, but this version isn't installing on my machines. I can see the version in the package list in my console, and the version is also correct in my package group, but when I force a refresh on my machines, they don't see the new version.
I tried a "forced" installation, but nothing happens there either.
Do you have any ideas or suggestions?
Thanks
, Benoit
Re: [Chrome] update 81.0.4044.129 which won't install
Published: April 29, 2020 - 12:16 PM
by sfonteneau
Hello
, did you download the Windows package and not the Linux or Darwin package?
Published: April 30, 2020 - 10:00 AM
by benoitpatin
I've never seen the Linux or Darwin packages?
I always go to "import from internet," check the "newer packages only" and "latest version only" boxes, and update my packages.
I don't get any errors during execution because it seems like it's not taking the new version into account.
Published: April 30, 2020 - 10:22 AM
by sfonteneau
The Linux and Mac packages have recently appeared in the repository; therefore,
we will soon add an "OS" filter to the "Import from Internet" option.
To verify the package, you can check the "target_os" column of the Chrome package.
Published: April 30, 2020 - 11:02 AM
by benoitpatin
I did indeed have a Darwin package.
I just put the Windows package back in my package group, but it didn't change anything. The PC still doesn't see the Chrome update.
Published: April 30, 2020 - 11:20 AM
by sfonteneau
Can you specify the Wapt version of the device?
Published: May 5, 2020 - 2:25 PM
by gauthier_leclercq
Here is the version of an affected machine: 1.7.4.6143.
Thank you.
Best regards.
Published: May 5, 2020 - 2:31 PM
by sfonteneau
https://wapt.tranquil.it/store/details- ... 1acca.wapt
It appears that our package now has a min_wapt_version : 1.8
Published: May 5, 2020 - 3:31 PM
Okay,
thank you very much.
We'll update the clients. :D
Re: [SOLVED] [Chrome] Update 81.0.4044.129 that won't install
Published: May 11, 2020 - 11:30 AM
by jpele
FYI, the package has been made backward compatible with WAPT 1.5
. Topic closed.
