Page 1 of 1
[RESOLVED] Firefox package deployment: [Error 5] Access denied
Published: June 9, 2020 - 3:39 PM
by jojo456
When deploying my Firefox.exe package, I encountered the error message [Error 5] Access denied in the console. There were no problems during local installation.
- Capture.PNG (60.28 KB) Viewed 5469 times
At first I thought my silentflag was faulty, but after some research it seems to be correct.
For your information, I am using Windows 10 on all my VMs and I have the latest version of WAPT.
Re: Firefox package deployment: [Error 5] Access denied
Published: June 9, 2020 - 9:46 PM
by dcardon
The first thing that comes to mind is an antivirus issue. Could you check the logs on that end?
Published: June 9, 2020 - 10:07 PM
by sfonteneau
Is your Firefox package version 18.5?
The binary is named "Firefox installer.exe".
The package clearly didn't originate from us.
Can you tell us where the file came from?
Can you also provide your setup.py file?
Published: June 10, 2020 - 10:59
by jojo456
Hello and thank you for your replies
The file comes from the official Firefox website.
Here is the setup.py file
- Capture1.PNG (8.77 KB) Viewed 5447 times
As for the antivirus, I'm going to uninstall Office Scan and test it
Published: June 10, 2020 - 9:36 PM
by sfonteneau
You're apparently using Firefox's auto-downloader; the installer isn't in the .exe file but downloads Firefox from the internet every time you change it.
Use this one instead:
https://download.mozilla.org/?product=f ... 64&lang=fr
Published: June 11, 2020 - 10:17
by jojo456
Yes, it was a file problem, thank you!
