[SOLVED] LdapS authentication issue
Published: July 2, 2020 - 10:18 AM
Hello everyone.
For the switch to wapt enterprise, I am currently configuring our new server (on debian).
All that's left for me is console authentication with LdapS.
And that's where I'm stuck… I followed the instructions exactly…
Authentication with local session: OK
LDAP authentication (non-S): OK (the connection request is clearly visible in the AD server)
LDAP authentication: not working => however, there is no connection request in the AD server.
However, on AD, the certificate is correctly installed with a known authority.
Just to be sure, I added this authority to the WAPT server. No changes…:
A telnet connection on port 636 (ldapS) from my wapt server to my AD server is functional.
(By the way, this reminds me that the documentation states that the default LdapS port is 646, whereas it's actually 636)
Here is my waptserver.ini (anonymized):
Here is the result of /opt/wapt/runwaptserver.sh -ldebug during identification:
The console won't connect
Thanks in advance !!
sudo cp TERENACA.crt /usr/local/share/ca-certificates
sudo update-ca-certificates(By the way, this reminds me that the documentation states that the default LdapS port is 646, whereas it's actually 636)
[options]
server_uuid = XXXXXXXXXXX
clients_signing_key = XXXXXXXXXXX
clients_signing_certificate = XXXXXXXXXXX
wapt_password = XXXXXXXXXXX
allow_unauthenticated_connect = False
secret_key = XXXXXXXXXXX
use_kerberos = True
wapt_huey_db = /opt/wapt/db/waptservertasks.sqlite
wapt_admin_group_dn=CN=group,CN=Users,DC=mydomain,DC=fr
ldap_auth_server=myserver.mydomain.fr
ldap_auth_base_dn=OU=mygroup,DC=mydomain,DC=fr
ldap_auth_ssl_enabled=True
Well... I'm not exactly an expert on logs, but in this case, I don't see...2020-07-02 10:08:45,001 [waptserver ] DEBUG (3174) accepted ('127.0.0.1', 59294)
2020-07-02 10:08:45,002 [root ] DEBUG Using monserver.mondomaine.fr as authentication ldap server
2020-07-02 10:08:45,003 [root ] DEBUG Using OU=mongroup,DC=mondomaine,DC=fr as base DN
2020-07-02 10:08:45,003 [root ] DEBUG using dc monserver.mondomaine.fr for authentication, with base DN OU=mongroup,DC=mondomaine,DC=fr and bind username monlogin@mondomaine.fr
2020-07-02 10:08:45,003 [root ] DEBUG Using ldaps for authentication
2020-07-02 10:08:45,012 [waptserver ] INFO ip.de.mon.AD,127.0.0.1 - - [02/Jul/2020 10:08:45] "POST /api/v3/login HTTP/1.0" 401 324 0.009679
2020-07-02 10:08:47,625 [waptserver ] INFO wsgi exiting
2020-07-02 10:08:47,625 [waptserver ] INFO (3174) wsgi exited, is_accepting=True
2020-07-02 10:08:47,625 [waptserver ] INFO Waptserver stopped
