Page 1 of 1
a planned task that self-destructs after completion
Published: July 23, 2020 - 11:54 AM
by florentR2
For mobile laptops on which the WAPT agent needs to be deployed, I refer to this section of the documentation:
https://www.wapt.fr/fr/doc/wapt-configuration ... duled-task
Next, specify a start time and indicate that the task should be repeated every 30 minutes or until successful:
However, I cannot find the option(s) to prevent the task from repeating once it has succeeded, or to prevent it from self-destructing once the wapt agent is deployed.
Do you think it's possible?
Re: Planned task that self-destructs after success
Published: September 30, 2020 - 2:25 PM
by florentR2
That doesn't seem possible?
