Page 1 of 1
Client integration into the domain is not possible
Published: August 24, 2020 - 11:32
by Plegrand
I'm using the following Samba version:
2:4.10.17+dfsg-0.1buster1 from the tranquil-it repositories.
Apparently (I'm not sure), since the last update, I can no longer integrate a Windows machine (1909).
The message isn't very clear because it only mentions an "internal error."
In the Event Viewer, I have this: Netjoint Event ID 4097 error code 1359.
Furthermore, I can't access the various consoles (Policy Management, Users and Computers) with a message saying that "the RPC server is unavailable" or that "the specified domain controller could not be contacted."
Any idea where the problem might be coming from?
Best regards
Re: Client integration into the domain impossible
Published: August 25, 2020 - 09:01
by dcardon
There are many possible reasons... Active Directory isn't simple in itself, whether it's Samba or MS. Without any logs, it's difficult to say. Does downgrading to a previous version change anything? What procedure was used? What still works? Are the DNS settings functioning? etc.
