Page 1 of 1
[RESOLVED] WAPTWUA Repository
Published: August 25, 2020 - 3:52 PM
by Jonathan K.
While waiting for a solution for a repository on a Pi, I am performing tests on a Debian system.
The repository is clearly visible in the repository tab, and it is properly synchronized.
I pushed the configuration to an OU (wapt-get.ini):
[global]
repo_url=https://depot-mas-tg.mondomaine.local/wapt
send_usage_report=1
use_hostpackages=1
wapt_server=https://srv-wapt.mondomaine.local
use_kerberos=0
check_certificates_validity=1
verify_cert=0
dnsdomain=
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
use_ad_groups=1
use_repo_rules=True
waptaudit_task_period=1d
use_fqdn_as_uuid=1
[wapt-templates]
verify_cert=1
[waptwua]
enabled=True
default_allow=false
install_at_shutdown=true
install_delay=7d
download_scheduling=1d
allow_direct_download = False
When I request an update check, I get the following error:
Start Windows Updates Scans
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download": false,
 "default_allow": false,
 "install_delay": "7d",
 "download_scheduling": "1d",
 "filter": "Type='Software' or Type='Driver'",
 "install_scheduling": null
Unable to refresh wsusscan cab, using old one. (error: ConnectionError: HTTPSConnectionPool(host='depot-mas-tg.mondomaine.local', port=443): Max retries exceeded with url: /waptwua/wsusscn2.cab (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x09598730>: Failed to establish a new connection: [Errno 10061] Aucune connexion n\x92a pu \xeatre \xe9tablie car l\x92ordinateur cible l\x92a express\xe9ment refus\xe9e',)))
Thank you for your help.
Re: WAPTWUA Repository
Published: August 25, 2020 - 4:10 PM
by dcardon
Hi Jonathan,
did you install the tis-enable-remote-repo-nginx package after deploying the agent on the Debian system?
Is the nginx process listening (netstat -tapn | grep 443 after installing net-tools)?
Is there a firewall configured on the machine (iptables -L)?
Published: August 25, 2020 - 4:48 PM
by Jonathan K.
The tis-enable-remote-repo-nginx package was not installed, now it is.
Here is the result of the command netstat -tapn |grep 443:
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      568/nginx: master p
And here is the result of a scan launched from the console:
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Waiting for WUA search to complete
Searching s
Searching 1s
Searching 2s
Searching 3s
Searching 4s
Searching 5s
Searching 6s
It seems to be ending without error, but I'm not sure.
Published: August 25, 2020 - 5:45 PM
by dcardon
Hi Jonathan,
you should be able to retrieve the status from the WAPT console under the Windows Update tab. It should show the installed KBs and the KBs awaiting installation.
Published: August 26, 2020 - 10:03
by Jonathan K.
Hi Denis
, that's all good for me, I do have pending updates.
Thanks, I'm marking this as resolved.
