Page 1 of 1
Problem registering client machines
Published: September 22, 2020 - 5:55 PM
by FitzXelia
I am creating this post because despite my searches on the forum, I cannot find a solution to my problem.
I have a WAPT server which is used for several domains with trust between them.
However, I am encountering problems with customer registration.
I use Kerberos authentication for registration.
Server Configuration:
[options]
waptwua_folder = /var/www/html/waptwua
server_uuid = f3b48752-1059-11ea-a519-005056b71f58
clients_signing_key = /opt/wapt/conf/ca-wapt1.domaine1.local.pem
clients_signing_certificate = /opt/wapt/conf/ca-wapt1.domaine1.local.crt
wapt_password = $pbkdf2-sha256$29000$2nvvfe.dk7K21vo/Z8z53w$DtkM/JsLTv7wx2MGRdapPIkCzkk46j3Bsu8Prv1NxvM
use_kerberos = True
allow_unauthenticated_connect = False
secret_key = UFoo6Qq2mLVIRwHnSZ0Wj2OoBBDhmvbApQH8jvHFtNltV8QzepPdXqfzanHOBywd
http_proxy =
wapt_admin_group_dn = CN=G_WAPT_Admin,OU=Groupes,DC=domaine1,DC=local
ldap_auth_server = AD1.domaine1.local
ldap_auth_base_dn = DC=domaine1,DC=local
ldap_auth_ssl_enabled = False
Client configuration:
[global]
waptupdate_task_period=120
wapt_server=https://wapt1.domaine1.local
repo_url=https://wapt1.domaine1.local/wapt
use_hostpackages=1
send_usage_report=1
use_kerberos=1
check_certificates_validity=0
verify_cert=C:\wapt\ssl\server\wapt1.domaine1.local.crt
dnsdomain=
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
use_fqdn_as_uuid=1
use_ad_groups=1
waptaudit_task_period=120m
[wapt-templates]
verify_cert=1
[waptwua]
enabled=false
install_at_shutdown=false
In the server logs:
Sep 22 17:44:38 wapt1 python: 2020-09-22 17:44:38,700 CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure(u'Unknown host UUID clientXX.domaine2.local. Please register first.',)
Attempting manual registration via wapt-get register:
Registering host against server: https://wapt1.domaine1.local
        System Power Controls
FATAL ERROR : HTTPError: 403 Client Error: Forbidden for url: https://wapt1.domaine1.local/add_host_kerberos
wapt-get exited on clientXX.domaine2.local with error code 3.
I checked the nginx server configuration and it is correct.
I don't see where the problem is coming from.
- Installed WAPT version 1.7.4
- CentOS 7.7 server operating system
Re: Problem registering client machines
Published: September 22, 2020 - 7:40 PM
by vcardon
Are you experiencing the same problem with version 1.8.2?
Regards.
Published: September 22, 2020 - 8:15 PM
by FitzXelia
It's a server installed with an enterprise version license that has expired and won't be renewed for the time being (we're in the middle of renewing/replacing our workstations, and the number of workstations in WAPT is higher than the actual number).
Therefore, I no longer have access to the repository to update it.
Published: September 22, 2020 - 8:57 PM
by vcardon
If you switched to the community plan because the number of PCs exceeded your number of purchased licenses, call the office; the adjustment will likely be minimal to get you back on track.
If you were on a trial plan, it's working as expected, and you'll need to seek answers from the community.
Published: September 23, 2020 - 10:05 AM
by FitzXelia
I think I've identified my problem.
My Active Directory on my first domain isn't delegating Kerberos tickets to my second domain.
This stems from a Microsoft update that disabled this by default.
Is there a way to switch from the Enterprise repository to the Community repository to perform the update without having to reinstall the server?
