Page 1 of 1
Incorrect version of Windows reinstalled
Published: September 29, 2020 - 9:36 PM
by dsi62
I'm working with WAPT Enterprise version 1.8.2. The WAPT server is running Windows.
I'm a complete beginner with WAPT.
I installed a WAPT agent on a Windows 7 Pro PC. I then manually updated the Windows version (without going through WAPT).
The WAPT console still displays Windows 7 Pro as the operating system.
I should mention that the time of the last contact between the WAPT server and the agent is correctly recorded, but the
PC is considered "Disconnected" (I don't know why).
Re: Wrong version of Windows reinstalled
Published: September 29, 2020 - 9:45 PM
by htouvet
The complete inventory isn't sent with every connection.
What's sent regularly are software, updates, packages, and other dynamic information (network, etc.).
To get an accurate, up-to-date view, you need to request an inventory update from the console (context menu on the machine / Refresh workstation inventory)
or schedule the periodic retrieval of information using an audit function.
You're not the first to mention this; we surely need to send this information back to the server when it changes... ;)
Published: October 1, 2020 - 11:35 AM
by dsi62
thank you very much for your reply.
It works when the remote computer is identified as reachable, but I'm having trouble with a computer on the network, which is powered on, and from which I load the homepage of my WAPT server, yet it's identified as "disconnected." As a result, the context menu you mentioned is grayed out.
Do you have any idea what the problem might be?
Thank you for your help.
Published: October 1, 2020 - 11:50 AM
by htouvet
If the device appears disconnected, it could be:
- because he's not on time?
- because it is no longer registered correctly (its public certificate is no longer valid in the database) -> test a "wapt-get register" on the client
- because a proxy is defined at the registry level for the system account (it happens...)
- because an antivirus intercepts the HTTPS stream and prevents the WebSocket from establishing itself
To better diagnose the problem, you can run the wapt service in debug mode:
in a command prompt with elevated administrator privileges:
runwaptservice.bat -l debug
and analyze the console output
[SOLVED] Wrong version of Windows reinstalled
Published: October 1, 2020 - 3:52 PM
by dsi62
the `wapt-get register` command allows the Windows version to be updated. The issue is therefore closed.
The "disconnected" message is still present. I will investigate other possibilities.
