Page 1 of 1
wapt console error
Published: October 9, 2020 - 9:38 AM
by Yann44
I'm getting an error when importing packages from the internet in the WAPT console. I'm getting the following message: "
Unable to import package: EWaptBadCertificate: Certificate None doesn't allow to sign packages with setup.py file."
Perhaps my public and private keys are in the wrong place?
Do you have any ideas?
Thank you.
Re: Wapt console error
Published: October 15, 2020 - 3:25 PM
by dcardon
Hello Yann44,
Yann44 wrote: ↑Oct 9, 2020 - 9:38 AM Hello,
I'm getting an error when importing packages from the internet in the WAPT console. I get the following message:
Unable to import package: EWaptBadCertificate: Certificate None don't allow to sign packages with setup.py file.
Indeed, it's probably a mix of keys. According to the message, the key used cannot be used to sign software packages (only machine configuration packages).
Denis Cardon
Published: November 24, 2020 - 1:34 PM
by Yann44
thank you for your reply.
I haven't been able to import packages for over six months, so I had abandoned that solution.
I'm now looking into the server again. I have two keys to run the crt and perm consoles. The question is, where should I save the files?
(Console on Windows 10, Wapt V1.8.1)
Thank you in advance
, Yann44
