[SOLVED] Registry key modification/computer description
Published: October 15, 2020 - 11:31
I am trying to modify the registry key corresponding to the computer description, located in HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\LanmanServer\Parameters
To do this, I need to retrieve the user logged in at time T, then retrieve information from the active directory.
My problem is retrieving the logged-in user using get_current_user:
Or is there another solution I haven't thought of?
Mathieu
- My initial idea is to retrieve the information using the `def install()` function: it assumes the logged-in user is System, which seems logical
- One workaround is to use session_setup; I can retrieve the logged-in user and all the Active Directory information, but I can't write the registry key because a non-administrator user doesn't have the necessary rights
Mathieu
