Page 1 of 1
Cross-platform package creation.
Published: October 26, 2020 - 1:55 PM
by Plegrand
is there a page explaining how to create a package using two installers depending on whether the platform is 32-bit or 64-bit?
Furthermore, is it possible to add installation options (msiexe) other than the default ones (/q /norestart)?
I want to generate an installation package for the GlobalProtect agent with the portal address as a parameter.
Thank you for your help.
Re: Creating a cross-platform package.
Published: October 26, 2020 - 4:39 PM
by Plegrand
Here is my configuration file, which seems to work
properties = {
'PORTAL':'portal.blabla.fr',
install_msi_if_needed('GlobalProtect.msi')
print(u'Installation en cours de GlobalProtect')
if iswin64():
print('installation version 64 bits')
install_msi_if_needed('GlobalProtect64.msi',properties = properties)
print('installation version 32 bits')
install_msi_if_needed('GlobalProtect.msi',properties = properties)
print(u'Installation terminée !')
pass
# put here what to do when package is removed from host
# implicit context variables are WAPT, control, user, params, run
def session_setup():
print('Session setup for %s' % control.asrequirement())
# put here what to do when package is configured inside a user session
def update_package():
pass
# put here what to do to update package content with newer installers.
# launched with command wapt-get update-package-sources <path-to-wapt-directory>
# implicit context variables are WAPT, basedir, control, user, params, run
# if attributes in control are changed, they should be explicitly saved to package file with control.save_control_to_wapt()
def audit():
pass
# put here code to check periodically that state is matching expectations
# return "OK", "WARNING" or "ERROR" to report status in console.
# all print statement are reported too
return "OK"
This file appears to work.
However, during the build process I get this message:
Please log in for
https://wapt.iut-chartres.lan/api/v3/upload_xxx:
What are these identifiers?
