External console tools
Published: November 10, 2020 - 1:22 AM
I'm looking into the console's external tools (version 1.7.3.5) and I have a few questions. Unfortunately, the online documentation is almost silent on plugins. Is there any additional documentation available? If not, could you answer a few questions I have so I can figure out how the external tools work on my own?
The example in the documentation, "Executable: explorer.exe Arguments: \\{ip}\c$", doesn't work on my console.
1st question: Is the specified executable the one on the console machine or the target machine?
2nd question: If an executable is specified in the arguments line, is it indeed an executable on the target machine?
3rd question: Is there a list of usable variables like {ip}, {uuid}...?
4th question: If I enter, for example, \\{ip} in the arguments field, it's transformed into \{ip} after validation. What escape character should I use before \\?
Question 5: Regarding execution rights in a domain, which user is used: the Windows session user on the console or the local SYSTEM user on the target machine?
For example, with psexec, by default in the command line, `psexec \\xxx.xxx.xxx.xxx shutdown /p` uses the rights of the domain user who opened cmd.exe on the console machine.
Do I need to upgrade my WAPT Enterprise server, or is version 1.7.3.5 fully functional with external tools?
Thank you in advance to anyone who takes the time to help me.
