XLSTAT deployment error
Published: Dec 1, 2020 - 6:08 PM
I just created an xlstat 2020 package:
- My pyscripter:
install_exe_if_needed("xlstat20202.exe",'/s',key='{683623D5-9911-441A-B65D-18158F7B3E22}',min_version='22.2.65349')
The install and uninstall test works correctly via PyScripter.
The problem is that when installing the package on a machine, it gives me the following error:
File "C:\Program Files (x86)\wapt\common.py", line 3823, in install_wapt
File "c:\windows\temp\waptl1puvs\setup.py", line 7, in install
File "C:\Program Files (x86)\wapt\common.py", line 3777, in new_func
return func(*args,**kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1263, in install_exe_if_needed
run(r'"%s" %s' % (exe,silentflags),accept_returncodes=accept_returncodes,timeout=timeout,pidlist=pidlist)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3867, in run
CalledProcessErrorOutput: Command '"xlstat20202.exe" /s' returned non-zero exit status -2147024893.
Output:
Output:
I have absolutely no idea where the problem could be coming from and I'm having trouble deciphering it.
- Installed WAPT version (1.8.1)
- Server OS (Windows 10)
- Administration/package creation machine OS (Windows 10)
Thank you for your help.
Adel
- My pyscripter:
Output:
Output:
Adel
