Page 1 of 1
Problem registering virtual workstations in WAPT
Published: Dec 17, 2020 - 12:48 PM
by Patrice_minagri
Hello
, I've noticed that virtual machines registered on the WAPT server disappear a few minutes after registration.
When I run `wapt-get register` on the virtual machine, it registers immediately on the server and appears
without issue in the WAPT console. However, a few minutes later, if I run the same search in the console again, the virtual machine has disappeared. Instead, a different virtual machine is displayed, even though the machine names don't match.
Has anyone else experienced this problem?
Thanks.
Pat
Re: Problem registering virtual workstations in WAPT
Published: Dec 17, 2020 - 2:37 PM
by Aedenth
I have several virtual machines on WAPT and I haven't encountered this problem.
It seems like a similar UUID issue.
WAPT identifies machines by their UUID and not by their name.
Have you tried running the command `wapt-get generate-uuid` on your virtual machine to see if that resolves the problem?
