Page 1 of 1
Permissions issues with the console
Published: February 16, 2021 - 4:33 PM
by t.heroult
Wapt Community: 1.8.2 (Linux)
Infrastructure: Windows 10
Hello
, When I try to create a new account to use the console (creating a new user certificate), I end up with a user who can only view the interface; they cannot change the configuration of the workstations, for example.
On the same installation, if I use my certificate, it works without any problem, so it's not a problem with the Wapt client configuration on the workstation.
What am I missing?
Tom
Re: Console permissions issues
Published: February 16, 2021 - 4:42 PM
by htouvet
This is the expected behavior...
To modify the machine's configuration, you must copy the certificate of this new user to the c:\program files(x86)^wapt\ssl directory of the machines that must be manageable by this user (and restart waptservice on these machines for the certificate to take effect).
The other option (with the Enterprise version) is to deploy an "authority" certificate (CA) on the machines and sign the certificates of the various users with the private key of this CA. The client workstations will then accept packets and actions signed by all users from this CA.
Published: February 16, 2021 - 4:54 PM
by t.heroult
Ah OK, I hadn't noticed that detail!
Thank you, it works perfectly. :)
Published: February 16, 2021 - 4:59 PM
by t.heroult
So, what method should be used to propagate the new certificates?
