Check starting mode Windows update service
Published: April 13, 2021 - 5:16 PM
Check the startup mode of the Windows update service (wuauserv).
If different from Automatic audit, refer to WARNING
def audit():
a = run_powershell('Write-Host (Get-Service "wuauserv").StartType',output_format='text')
lines = a.split("\n")
print('Mode de demarrage du service wuauserv : %s' % lines[0])
if lines[0] == 'Automatic':
return "OK"
print('LE SERVICE WINDOWS UPDATE N EST PAS EN DEMARRAGE AUTO ! VERIFIER POURQUOI')
return "WARNING"
