Page 1 of 1
wapt 2.0 problems encountered
Published: April 22, 2021 - 8:13 AM
by yann83
I'm currently testing WAPT version 2.0.
I find using certificates extremely complicated, even though there are several pages in the manual on the subject, but I don't find it very clear. Perhaps a quick start section with minimal instructions would help.
I encountered a bug in the package add wizard; it doesn't take into account the "Silent options" field when I click on "Edit manually." This happened to me twice.
When editing in pysrypter, it's always in Python version 2, while WAPT 2.0 uses version 3, which I don't quite understand.
In the script, the Uninstallkey, entered like this: uninstallkey = ["{guiid}"] or uninstallkey = ["nomprogramme_is1"] (a key present in the registry in the uninstall section), has never worked.
The def uninstall() function must always be filled in.
Editing packages is a nightmare to use! Indeed, you should read about package cloning rather than editing, because not only does it create a new package every time you change the content, but it also increments the version number systematically. While this doesn't affect the package itself, it makes readability and tracking impossible. This is especially true for versions like 04.02.00, which becomes 04.02.1.
Do you have any solutions for the problems I'm encountering?
Thank you.
Re: wapt 2.0 problems encountered
Published: April 22, 2021 - 12:14 PM
by erenodau
Hello Yann83,
Thank you for your feedback. We are currently working on improving the documentation.
Regarding editing via PyScripter, your problem may be related to a simple display issue. WAPT 2.0 does indeed use Python 3. It's also possible that you have some remnants of Python 2 on your machine.
Concerning the uninstall key, I suggest you share a code example on the forum. Otherwise, it's quite difficult to help you.
The incrementing of version numbers is intentional and an integral part of how WAPT works; everything is explained here: https://www.wapt.fr/fr/doc/wapt-package ... ml#version.
We also encourage you to explore the packages we offer on the WAPT Store; they may be useful: https://store.wapt.fr/.
You can also benefit from more in-depth support from our team:
- Through a support package: https://www.tranquil.it/gerer-parc-info ... port-wapt/
- Through WAPT training: https://www.tranquil.it/gerer-parc-info ... tion-wapt/.
Feel free to contact us to discuss these options. Have
a great day!
Published: April 26, 2021 - 2:43 PM
by sfonteneau
yann83 wrote: ↑Apr 22, 2021 - 8:13 AM I find using certificates very, very complicated. There are several pages in the manual on the subject, but I don't find it very clear. Perhaps a quick start section with minimal instructions could help.
We've just added a simple way to create a certificate copy package on clients to the package creation wizard, which should make things easier. It will be released soon
yann83 wrote: ↑Apr 22, 2021 - 08:13 I encountered a bug in the package add wizard; it doesn't take into account the "Silent options" field when I click on edit manually. It happened to me twice.
I just tested it with an executable and I don't encounter the problem in version 2.0
yann83 wrote: ↑Apr 22, 2021 - 08:13 When editing in pysrypter, we are always in python version 2 while Wapt 2.0 uses version 3, I don't quite understand.
If you previously had version 1.8, it's possible the name in PyScripter hasn't updated correctly. You can check in PyScripter by going to "Run" -> "Python Version" -> "Set Python Versions"; you should find the path to the WAPT installation folder there.
yann83 wrote: ↑Apr 22, 2021 - 08:13 In the script, the Uninstallkey, entered like this: uninstallkey = ["{guiid}"] or uninstallkey = ["nomprogramme_is1"] (key present in the registry in the uninstall section), has never worked.
You must always fill in the def uninstall()
For the remove function to work without going through uninstall, it is absolutely necessary to have put the key either in the uninstallkey variable or in install_exe_if_needed or in install_msi_if_needed.
But the following subtlety is important: To test correctly with remove, you must always have launched an installation beforehand, because the code executed during uninstallation is the one that was stored in the sqlite database, and the code is only written during installation.
One thing to remember then: if you have just added the key you must always restart the installation before attempting to uninstall.
yann83 wrote: ↑Apr 22, 2021 - 08:13 Package editing is a nightmare to use! You should really read about package cloning rather than editing, because not only does it create a new package every time you change the content, but it also increments the version number systematically. While this doesn't affect the package itself, it makes it impossible to read and track. Especially for versions like 04.02.00 which becomes 04.02.1.
When you build your package, WAPT increments the package version. That's why all packages end with -0. In your example, the package version should therefore be 04.02.00-0, and after upload, it will become 4.2.0-1. WAPT does not automatically delete old packages; you must do so yourself if you really want to.
Published: April 29, 2021 - 11:33 AM
by yann83
First of all, a big thank you for your feedback.
The silent options are correctly entered in setup.py, maybe I made a mistake or an error.
For Python, it's strange:
I'll let you see for yourself:
https://imgur.com/AskZTkg
I have two versions.
For uninstallation, here is an example:
https://imgur.com/WX3a6yQ
So by default, when I generate a package, the uninstallation key is not displayed in uninstallkey
By default, the program is not installed on the computer. I'm running the installation first.
uninstallkey = ['2BC24DC9-F397-4021-A4FC-A3571898E856_is1']
    install_exe_if_needed("Setup_Infos_Support_3.7.3.exe",'/VERYSILENT /NORESTART /LOG=C:\PMF\RAPPINST\WAPT_InfosSupport.log',key='2BC24DC9-F397-4021-A4FC-A3571898E856_is1',min_version='3.7.3')
    pass
    # put here what to do when package is removed from host
    # implicit context variables are WAPT, control, user, params, run
def session_setup():
    print('Session setup for %s' % control.asrequirement())
    # put here what to do when package is configured inside a user session
def update_package():
    pass
    # put here what to do to update package content with newer installers.
    # launched with command wapt-get update-package-sources <path-to-wapt-directory>
    # implicit context variables are WAPT, basedir, control, user, params, run
    # if attributes in control are changed, they should be explicitly saved to package file with control.save_control_to_wapt()
def audit():
    pass
    # put here code to check periodically that state is matching expectations
    # return "OK", "WARNING" or "ERROR" to report status in console.
    # all print statement are reported too
    return "OK"
Published: April 29, 2021 - 11:47 AM
by sfonteneau
Based on your code, it should look like this:
    install_exe_if_needed("Setup_Infos_Support_3.7.3.exe",'/VERYSILENT /NORESTART',key='2BC24DC9-F397-4021-A4FC-A3571898E856_is1',min_version='3.7.3')
If you don't have {} do not add them to the uninstallkey
Remember to reinstall the system before testing the uninstallation
If you specify the key in the install_exe_if_needed function, there's no need to put uninstallkey in the list at the top
For the Python version, it's just a problem with the name display in PyScripter. (You can rename it manually in PyScripter and name it wapt.).
Published: April 29, 2021 - 2:10 PM
by yann83
Thanks to Pyscrypter, it solved my problem.
However, I still can't uninstall a piece of software.
This time I tried with third-party software:
https://ultraviewer.net/en/download.html
Here is the code I used:
    install_exe_if_needed("UltraViewer_setup_6.2_en.exe",'/VERYSILENT /SUPPRESSMSGBOXES /NORESTART',key='{E0FABD74-083B-47F4-AC5B-CA4237BF8913}_is1',min_version='6.2')
    pass
The installation is OK but not the uninstallation.
The console output is as follows:
Ligne de Commande : uninstall "C:\waptdev\118301-ultraviewer-wapt\WAPT\.."
Uninstalling C:\waptdev\118301-ultraviewer-wapt ...
None
Uninstallation done
I don't understand where I'm going wrong.
