Page 1 of 1
[SOLVED] Upgrade 1.8 Community -> 1.8 Enterprise
Published: May 12, 2021 - 12:06 PM
by olaplanche
I can't find the appropriate procedure in the documentation for what I want to do.
I would like to upgrade to the enterprise version without changing the version number initially.
So I tested it:
Change the repository to the enterprise repository using my credentials, then force a reinstallation of the packages with the command:
apt --reinstall install tis-waptserver tis-waptrepo tis-waptsetup
I restarted the postconf and regenerated the WAPT agent, but when I download the agent setup from my WAPT repository, it's still the community version setup
I must be forgetting something, do you have any idea?
THANKS
Re: Upgrade 1.8 Community -> 1.8 Enterprise
Published: May 12, 2021 - 12:15
by Gaetan
did you do a remove and then an install rather than a reinstall?
Was an update performed correctly?
Published: May 12, 2021 - 2:23 PM
by olaplanche
Okay, after checking the /etc/apt/sources.list.d/wapt.list file, the repository update command didn't work. :roll:
It works much better with the correct repository configured now. :mrgreen:
Sorry for the inconvenience. :lol:
Published: May 12, 2021 - 2:32 PM
by Gaetan
:D
Great ;)
