Page 1 of 1
[SOLVED] wapt 1.8 and 2.0 in parallel
Published: May 13, 2021 - 09:57
by nliaudat
To ensure a smooth migration between WAPT 1.8 and 2.0, I would like to install a new server running version 2.0 alongside the existing 1.8 server.
Technically, is it possible for client workstations to have two different versions of the WAPT agent?
Given the package migration issues, this seems like the best solution.
Regards
Re: wapt 1.8 and 2.0 in parallel
Published: May 18, 2021 - 09:03
by dcardon
Hello nliaudat,
it is possible to install agent 2.0 on a client machine connected to a 1.8.2 server. Afterwards, you import all the packages and then check which ones install correctly and which ones don't.
Regards,
Published: May 18, 2021 - 10:49
by nliaudat
THANKS
