Using the WAPT key to sign external executables
Published: May 17, 2021 - 1:42 PM
here's a tip to share for anyone who might find themselves in a similar situation:
I have an executable I compiled myself using AutoIt, which I use to map a network drive. To deploy it, I created a simple WAPT package that pastes the file into the desired location.
The problem is that Windows 10, in its latest virus definitions, flagged me as a malicious publisher and deleted my executable.
The solution is to use the WAPT private key to sign the package. Since the affected machines have this key by definition, the executable no longer causes any problems.
For the signature, I used the signtool, which is part of Visual Studio (Win10 SDK).
Hope this helps someone...
