Problem during file copy
Published: May 20, 2021 - 2:18 PM
Good morning !
I am currently packaging LibreOffice for my company, with some features that I have added to the LibreOffice configuration files located in the Roaming.
I would like my pre-configured "LibreOffice" file to be moved from the package to my user directory during the installation of my package. I therefore made a copy of the file located in the package to the root of my PC.
then with the def session setup(): I move it into the file usersUnfortunately, it doesn't work, and I've been racking my brains for a while now without finding a solution.
The copy doesn't even go to the PC's root directory, so it's impossible to move it to the user folder.
Here is my code:
Here is my code:
copytree2('LibreOffice','C:\Program Files (x86)')
argument = {}
if not installed_softwares('Microsoft Office'):
argument = {'SELECT_WORD':1,'SELECT_EXCEL':1,'SELECT_POWERPOINT':1,'CREATEDESKTOPLINK':0,'RebootYesNo':'No','ALLUSER':1,'ISCHECKFORPRODUCTUPDATES':0,'QUICKSTART':0}
argument = {'CREATEDESKTOPLINK':0,'RebootYesNo':'No','ALLUSER':1,'ISCHECKFORPRODUCTUPDATES':0,'QUICKSTART':0}
install_msi_if_needed('LibreOffice_7.0.5_Win_x64.msi',properties=argument)
# Suppression des raccourcis
for wrongshortcutname in wrongshortcutnames:
remove_desktop_shortcut(wrongshortcutname)
remove_programs_menu_shortcut(wrongshortcutname)
if isdir(makepath(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs', wrongshortcutname)):
remove_tree(makepath(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs', wrongshortcutname))
# Creation du raccourci dans le bon dossier
if not matiere == '':
if default_target != '':
target = default_target
softs = get_softs()
if len(softs) > 0:
if (softs[0]['install_location'] == ''):
raise Exception('install_location', 'Impossible de trouver le dossier d\'installation, veuillez remplir la variable default_target')
target = makepath(softs[0]['install_location'], tasks_to_kill[0])
if not isfile(target):
raise Exception('target', 'Impossible de trouver l\'executable pour creer le raccourci')
create_programs_menu_shortcut(shortcutname, target=target, folder=matiere)
def session_setup():
copytree2('C:\Program Files (x86)\LibreOffice',makepath(user_appdata(),'LibreOffice'),onreplace=default_overwrite)
