Package deployment help
Published: May 27, 2021 - 5:19 PM
I'd like to change the installation folder of a package using PyScripter. (I have no knowledge of Python; I modified a basic script until I got this:)
Note that remove_desktop_shortcut works from pyscripter but from wapt when I uninstall a package from a client machine it does not remove the shortcut.
I would therefore like to know if it is possible to modify the installation path of a package with an option to add to the code and also why remove_desktop_shortcut does not work.
Thank you,
Matteo.
create_desktop_shortcut(r'nom_raccourci', target=r'C:\Program Files (x86)\…\.exe')
install_exe_if_needed("xx.exe",'/S /v/qn',
key='{clé}',
min_version="x.x",
killbefore="javaw.exe")
run(r' MsiExec.exe /X{clé} /qn')
remove_desktop_shortcut(r'nom_raccourci')
Thank you,
Matteo.
