[SOLVED] Help creating registry key, thank you
Published: June 8, 2021 - 11:50 AM
I want to merge a registry key during the ultravnc deployment.
I tried with
THIS SCRIPT
But this is causing me a problem with the creation of the registry because the values do not appear in the correct order at the registry key level.
Do you have a solution?
So I thought about automating the installation using the command prompt, but I don't have the necessary knowledge.
PS: For type 0x00000003, this is equivalent to reg_binary; it's the only way I was able to implement it
DO YOU HAVE A SOLUTION?
Thanks in advance
I tried with
THIS SCRIPT
registry_setstring( HKEY_LOCAL_MACHINE,"SOFTWARE\ORL\WinVNC3",'ACL','06,25,50,00,02,00,00,00,00,00,27,00,03,00,00,00,01,07,00,10,00,00,00,\
78,15,00,00,00,7f,46,02,50,18,3f,d5,03,b4,08,ba,43,8e,54,00,00,00,00,24,00,\
07,00,01,00,01,05,00,00,04,00,00,05,15,00,48,00,8f,46,02,50,78,3f,d5,03,b4,\
02,ba,43,00,02,00,00', type=0x00000003)
Thanks in advance
