Adobe Reader package problem
Published: June 9, 2021 - 12:18 PM
Hello everyone,
Adobe released a new version of Adobe Reader on its website with an incorrect version number and which did not install correctly.
Our builder subsequently adopted this version number, and between May 11th and May 21st, a package with an incorrect Adobe Reader version number was published on our store: tis-Adobereader_2021.1.200150-51, which we quickly removed.
We have just released version 2021.1.200155, which works without any issues. However, if you used the previous version, you will need to remove version 2021.1.200150 from your repository.
We've also added a package to our store to clean up computers that may have downloaded it, allowing them to install the latest version instead: https://store.wapt.fr/store/tis-fix-wapt-packages.
This package lets you define a list of packages and their versions to automatically forget on all computers where you install it. By default, it's configured to forget Adobe Reader version 2021.1.200150, which is relevant to us today.
This package is useful in this case, but also for forgetting packages whose names you've changed; it simply removes the package and installs the correct version.
Have a great day everyone!
