[SOLVED] windows update management
Published: August 30, 2021 - 2:27 PM
Hello
, I have noticed that KBs are being installed on workstations in our network even though we have not yet authorized them.
If below the file wapt-get.ini
[global]
repo_url=https://carbone.utt.fr/wapt
send_usage_report=1
use_hostpackages=1
wapt_server=https://carbone.utt.fr
use_kerberos=0
check_certificates_validity=1
verify_cert=C:\Program Files (x86)\wapt\\ssl\server\carbone.utt.fr.crt
use_repo_rules=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
waptaudit_task_period=120m
[wapt-templates]
verify_cert=1
[waptwua]
default_allow=False
install_at_shutdown=true
enabled = true
allowed_severities = Critical,Important
download_scheduling = 7d
[global]
send_usage_report=1
use_hostpackages=1
use_kerberos=0
use_repo_rules=0
hiberboot_enabled=0
[wapt-templates]
verify_cert=1
[waptwua]
default_allow=False
enabled = true
