package installation problem
Published: September 21, 2021 - 12:06 PM
- Installed WAPT version (1.8.2)
- Server OS (Linux) and version (ubuntu 20.04 LTS)
- Operating system of the administration/package creation machine (Windows 10)
We deployed WAPT 1.8.2 Community on our network. The tool works correctly and we were able to create our own packages.
However, we are encountering a problem with a package we created.
Originally, it was an .exe generated by the ESET console which deployed an agent and the antivirus.
The deployment went well and the antivirus and agent installed correctly on the machine.
However, WAPT continues to reinstall it on the machine.
The logs show that wapt considers the package not to be installed.
Is there a setting or key that allows an installation to be acknowledged?
Here is the error message that the console is giving me:
And here's what the audit revealed:
Thank you in advance for your feedback.
Greetings
Installing me-eset-security_V2(=7.2.1266.0-2)
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1892, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 653, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1126, in _run
Exception: Erreur lors de l'installation de [u'me-eset-security_V2(=7.2.1266.0-2)']: erreurs dans les paquets [[PackageRequest(package=u'me-eset-security_V2',version=(Version('7.2.1266.0'), 2),architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],target_os=[u'windows'],min_os_version=Version('10.0.19042'),max_os_version=Version('10.0.19042')), PackageEntry(u'me-eset-security_V2',u'7.2.1266.0-2' maturity=u'PROD'), u'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4957, in install\n force=force\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3965, in install_wapt\n raise e\nCalledProcessErrorOutput: Command \'"ESMC_Installer_x64_fr_FR.exe" --silent --accepteula\' returned non-zero exit status 5002.\nOutput:\n']]
self._run()
Exception: Erreur lors de l'installation de [u'me-eset-security_V2(=7.2.1266.0-2)']: erreurs dans les paquets [[PackageRequest(package=u'me-eset-security_V2',version=(Version('7.2.1266.0'), 2),architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],target_os=[u'windows'],min_os_version=Version('10.0.19042'),max_os_version=Version('10.0.19042')), PackageEntry(u'me-eset-security_V2',u'7.2.1266.0-2' maturity=u'PROD'), u'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4957, in install\n force=force\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3965, in install_wapt\n raise e\nCalledProcessErrorOutput: Command \'"ESMC_Installer_x64_fr_FR.exe" --silent --accepteula\' returned non-zero exit status 5002.\nOutput:\n']]Code: Select all
Auditing me-eset-security_V2(=7.2.1266.0-2)
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1209, in _run
self.result.append(u'%s: %s' % (package,self.wapt.audit(package,force = self.force)))
File "C:\Program Files (x86)\wapt\common.py", line 6558, in audit
raise Exception('Package %s is not installed' % package)
Exception: Package me-eset-security_V2(=7.2.1266.0-2) is not installed
self._run()
Exception: Package me-eset-security_V2(=7.2.1266.0-2) is not installedGreetings
