Page 1 of 1
HP Support Assistant Package
Published: October 28, 2021 - 6:07 PM
by Pierre Baridon
has anyone here ever worked on a package to deploy "HP Support Assistant" (an update/support tool for HP workstations)?
I'm having some difficulty with the package. Installation with an administrator account is no problem, however, with the local system account at boot, some dependencies fail to install.
Thanks!
Pierre
Re: HP Support Assistant Package
Published: February 3, 2022 - 12:14 AM
by Eddy
Good evening,
could you share your script?
I'm not particularly familiar with Python.
After trying several scripts, an error occurs every time...
Thanks in advance
, Eddy
Published: June 9, 2022 - 5:25 PM
by Pierre Baridon
Here is the first draft of my script:
import time
CommandVendor = 'wmic systemenclosure get manufacturer'
CommandModel = 'wmic COMPUTERSYSTEM get Model'
Vendor = str(run(CommandVendor))
Model = str(run(CommandModel))
    # Declaring local variables
    print ("Fabricant : ", Vendor)
    print ("Model : ", Model)
    if Vendor.find('HP') != -1 :
        print("Installation Prerequis")
        print("Installation de HP Support Assistant sur machine HP")
        # Installing the software
        print("Installing: %s" % control.package)
        #install_exe_if_needed('InstallHPSA.exe',
        #    silentflags='/S /v/qn',
        #    key='',
        #    min_version=control.get_software_version(),
        install_exe_if_needed('setup.exe',
            silentflags='-s',
            key='',
        print("Pas un materiel HP")
    print("désinstallation de HP Support Assistant")
    run ('"' + makepath(programfiles32,'HP','HP Support Framework','UninstallHPSA.exe') + r'" /S /v/qn')
Published: June 10, 2022 - 09:39
by florentR2
I've noticed that HPIA doesn't necessarily require installation.
You can simply retrieve the folder from a PC where it's installed. I chose this solution and then set up a scheduled task that launches HPIA tasks via the command line.
Published: June 22, 2022 - 5:03 PM
by Pierre Baridon
florentR2 wrote: ↑June 10, 2022 - 9:39 AM Hello,
I noticed that HPIA doesn't necessarily require installation.
Do you have any documentation/examples for launching tasks via the CLI?
Published: June 22, 2022 - 5:08 PM
by florentR2
There's a CLI section in the documentation: https://ftp.hp.com/pub/caps-softpaq/cmi ... rGuide.pdf
