Page 1 of 1
[SOLVED] Arduino Package
Published: Dec 15, 2021 - 08:37
by olaplanche
Changelog of 24/03/2022:
- Correction of the def install() function: which could not work in its current state!
I'm sharing my package for the Arduino software I just created:
Control file:
package           : wapt-arduino
version           : 1.8.16-2
architecture      : all
section           : base
priority          : optional
name              :
categories        :
maintainer        : olaplanche
description       : Arduino IDE
depends           :
conflicts         :
maturity          : PROD
locale            :
target_os         : windows
min_wapt_version  :
sources           : https://www.arduino.cc/en/software
installed_size    :
impacted_process  : arduino
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Arduino.cc
keywords          :
licence           :
homepage          : www.arduino.cc
package_uuid      :
valid_from        :
valid_until       :
forced_install_on :
changelog         :
min_os_version    :
max_os_version    :
icon_sha256sum    :
Setup file:
import platform
bin_name_string = 'arduino-%s-windows.exe'
    # Declaring local variables
    bin_name = bin_name_string % package_version
    impacted_process = control.impacted_process.split(",")
    # Installing the software
    print("Installing: %s" % bin_name)
    install_exe_if_needed(bin_name,
        silentflags='/S',
        key='Arduino',
        min_version=package_version,
        killbefore=impacted_process,
def update_package():
    result = False
    proxies = get_proxies()
    if not proxies:
    app_name = control.name
    url = control.sources
    # Getting latest version from official website
    version_temp = bs_find_all(url, 'span', 'class', 'download-title',proxies=proxies)[0].string
    version = version_temp[-6:]
    latest_bin = bin_name_string % version
    download_url = 'https://downloads.arduino.cc/arduino-%s-windows.exe' % version
    print("Latest %s version is: %s" % (app_name, version))
    print("Download URL is: %s" % download_url)
    # Downloading latest binaries
    if not isfile(latest_bin):
        # Checking version from file
        version_from_file = get_version_from_binary(latest_bin)
        if not version_from_file.startswith(version) and version_from_file != '':
            print("Changing version to the version number of the binary (from: %s to: %s)" % (version, version_from_file))
            os.rename(latest_bin, bin_contains + version_from_file + ends_bin_name)
            version = version_from_file
            print("Binary file version corresponds to online version")
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        result = True
        print("Software version up-to-date (%s)" % Version(version))
    control.version = '%s-%s' % (Version(version), control.version.split('-', 1)[-1])
    #control.set_software_version(version)
    # Deleting outdated binaries
    # Validating update-package-sources
    return result
def get_proxies():
    if platform.python_version_tuple()[0] == '3':
        from urllib.request import getproxies
        from urllib import getproxies
    return getproxies()
def get_version_from_binary(filename):
    if filename.endswith('.msi'):
        return get_msi_properties(filename)['ProductVersion']
        return get_file_properties(filename)['ProductVersion']
def remove_outdated_binaries(version, list_extensions=['exe','msi','deb','rpm','dmg','pkg'], list_filename_contain=None):
    if type(list_extensions) != list:
        list_extensions = [list_extensions]
    if list_filename_contain:
        if type(list_filename_contain) != list:
            list_filename_contain = [list_filename_contain]
    list_extensions = ['.' + ext for ext in list_extensions if ext[0] != '.']
    for file_ext in list_extensions:
        for bin_in_dir in glob.glob('*%s' % file_ext):
            if not version in bin_in_dir:
                remove_file(bin_in_dir)
                for filename_contain in list_filename_contain:
                    if not filename_contain in bin_in_dir:
def get_proxies_from_wapt_console():
    proxies = {}
    if platform.system() == 'Windows':
        waptconsole_ini_path = makepath(user_local_appdata(), 'waptconsole', 'waptconsole.ini')
        waptconsole_ini_path = makepath(user_home_directory(), '.config', 'waptconsole', 'waptconsole.ini')
    if isfile(waptconsole_ini_path):
        proxy_wapt = inifile_readstring(waptconsole_ini_path, 'global', 'http_proxy')
        if proxy_wapt:
            proxies = {'http': proxy_wapt, 'https': proxy_wapt}
    return proxies
    print("Uninstalling: %s" % control.package)
    run(r'"%s\Arduino\uninstall.exe" /s' % programfiles32)
Re: [SOLVED] Arduino Package
Published: Dec 16, 2021 - 2:43 PM
by olaplanche
Haha, Arduino version 1.8.16 is affected by the log4shell vulnerability (https://support.arduino.cc/hc/en-us/art ... 2021-44228). I'm really glad to have the update_package function to update to version 1.8.18 in 4 clicks. :D
Published: May 10, 2022 - 10:03
by gaelds
Thanks for this package! It installs fine, but the update-package-sources function gives me this error:
Ligne de Commande : update-package-sources "C:\waptdev\dst-arduino-windows-wapt\WAPT\.."
Using config file: C:\Users\informatique\AppData\Local\waptconsole\waptconsole.ini
2022-05-10 10:02:29,368 CRITICAL Fatal error in update_package function: NameError: global name 'bs_find_all' is not defined:
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 2449, in call_setup_hook
    hookdata = hook_func()
  File "C:\waptdev\dst-arduino-windows-wapt\setup.py", line 44, in update_package
FATAL ERROR : NameError: global name 'bs_find_all' is not defined
Exit code:  3
Published: May 10, 2022 - 5:42 PM
by dcardon
Which version of WAPT (see forum rules above)?
Published: May 11, 2022 - 09:38
by olaplanche
the bs_find_all function is defined in the setuphelper file since I don't know which version :D
. We should probably look there!
