Page 1 of 1
Waptconsole menu greyed out Windows 11
Published: February 25, 2022 - 3:30 PM
by Aedenth
Following a switch to Windows 11 for testing purposes, I no longer have access to certain menus in the wapt console.
I no longer have access to:
- Check for updates
- Run installations
- Install a package
- Force installation
- Uninstall a package
- Forget packages.
These menus are grayed out.
I have copied the certificates from my old machine, as well as the waptconsole.ini file.
Any idea what the problem might be?
Re: WaptConsole menu greyed out Windows 11
Published: March 3, 2022 - 4:34 PM
by dcardon
Hello Aedenth,
if the action menus are grayed out, it means the console can't find the private key corresponding to the public key deployed on the workstations in your local configuration.
If you correctly copied your private key, you need to check that it's properly referenced in the console preferences.
Regards,
