[SOLVED] Certificate package in error
Published: May 2, 2022 - 10:53
I am currently testing WAPT Enterprise on a demo license.
I created a group of certificate packages linked to my users, and when I try to deploy them, here is the error log I get:
WAPT2.2 ENTERPRISE, Debian 10 Linux Server, Windows 10 administration machine.
Thank you in advance for your feedback.
Installing cam-cert-adm-etiphaneau(=1.0-1)
Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n print("Certificate %%s found" %% (crt_location))\n ^\nSyntaxError: invalid syntax\n']]
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1880, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1229, in _run
Exception: Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n print("Certificate %%s found" %% (crt_location))\n ^\nSyntaxError: invalid syntax\n']]
self._run()
Exception: Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n print("Certificate %%s found" %% (crt_location))\n ^\nSyntaxError: invalid syntax\n']]Thank you in advance for your feedback.
