Page 1 of 1
[SOLVED] Kerberos and Selfservice
Published: May 4, 2022 - 11:19 AM
by Renaud Villet
we have configured Kerberos for machine registration, and it works well. However, since version 2.1, self-service no longer launches on client machines, without any error message, but it does launch correctly when we set `use_kerberos=0` in `wapt-get.ini`.
Thank you for your help.
Re: Kerberos and Selfservice
Published: May 4, 2022 - 2:25 PM
by sfonteneau
Good morning
For Kerberos authentication in self-service
Is the wapt-get.ini file on the agent correctly configured in this mode?
[global]
use_kerberos=True
service_auth_type=waptserver-ldap
And on the Wapt server in /opt/wapt/conf/waptserver.ini
[options]
ldap_auth_server = srvads.mydomain.lan
ldap_auth_base_dn = DC=mydomain,DC=lan
ldap_account_service_login = wapt-ldap@mydomain.lan
ldap_account_service_password = password
What is often forgotten is to add ldap_account_service_login and ldap_account_service_password
Without this, the server can authenticate the user correctly but cannot know which groups they belong to
Published: May 5, 2022 - 2:07 PM
by Renaud Villet
OK great, it works.
Thank you!
Re: [SOLVED] Kerberos and Selfservice
Published: May 5, 2022 - 5:50 PM
by smandel
I've applied the configuration correctly, but nothing is happening either.
Authentication works for agents trying to connect to the server.
Where can I view the logs?
Thank you.
Published: May 5, 2022 - 5:56 PM
by smandel
Everything is fine after adding:
THANKS !
