Page 1 of 1
[SOLVED] Registry Key Package
Published: May 6, 2022 - 5:01 PM
by eliottiph
- Installed WAPT version: WAPT 2.2.11899
- Server OS: Debian 10
- DHCP Server: Win19 Server
- Operating system of the administration/package creation machine: Windows Server 19
I'm trying to create a package to install a registry key.
from setuphelpers_windows import *
        pass
        pass
def session_setup():
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41,1f,00,00,53,08,ad,ba,03,00,00,00,8c,00,00,00,01,00,00,00,03,00,00,00,0c,00,00,00,61,b0,8c,da,26,49,d6,01,01,00,00,00,0f,00,31,00,36,00,34,00,2e,00,31,00,33,00,38,00,2e,00,32,00,34,00,32,00,2e,00,31,00,39,00,37,00,0c,00,00,00,80,a6,a4,f5,fb,55,d6,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,36,00,37,00,0c,00,00,00,07,6d,09,61,c6,ae,d7,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,35,00,38,00', type=winreg.REG_BINARY)
    print ('Installation de la clé de registre GCE')
Here is the error:
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 2974, in call_setup_hook
    hookdata = hook_func()
  File "c:\waptdev\keyregistry-GCE_0_PROD-wapt\setup.py", line 12, in session_setup
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41 1f 00 00 53 08 ad ba 03 00 00 00 8c 00 00 00 01 00 00 00 03 00 00 00 0c 00 00 00 61 b0 8c da 26 49 d6 01 01 00 00 00 0f 00 31 00 36 00 34 00 2e 00 31 00 33 00 38 00 2e 00 32 00 34 00 32 00 2e 00 31 00 39 00 37 00 0c 00 00 00 80 a6 a4 f5 fb 55 d6 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 36 00 37 00 0c 00 00 00 07 6d 09 61 c6 ae d7 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 35 00 38 00', type=winreg.REG_BINARY)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3825, in registry_set
    return reg_setvalue(key, keyname, value, type=type)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 447, in reg_setvalue
    return winreg.SetValueEx(key, name, 0, type, value)
TypeError: Objects of type 'str' can not be used as binary registry values
Thanks in advance.
Re: Registry key package
Published: May 6, 2022 - 5:37 PM
by htouvet
The hexadecimal string needs to be decoded to transform it into binary data.
To do this, you need to import the "binascii" module and use the unhexlify function, I think.
import binascii
        pass
        pass
    bindata = binascii.unhexlify('41,1f,00,00,53,08,ad,ba,03,00,00,00,8c,00,00,00,01,00,00,00,03,00,00,00,0c,00,00,00,61,b0,8c,da,26,49,d6,01,01,00,00,00,0f,00,31,00,36,00,34,00,2e,00,31,00,33,00,38,00,2e,00,32,00,34,00,32,00,2e,00,31,00,39,00,37,00,0c,00,00,00,80,a6,a4,f5,fb,55,d6,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,36,00,37,00,0c,00,00,00,07,6d,09,61,c6,ae,d7,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,35,00,38,00'.replace(',',''))
    registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter',bindata  , type=winreg.REG_BINARY)
Published: May 10, 2022 - 3:53 PM
by eliottiph
Hello htouvet,
Thank you very much for your help. :)
However, the target machine only installs the registry key on its local master account.
Is there a solution to overcome this and install the registry key on all sessions?
Thank you in advance.
Published: June 29, 2022 - 12:15 PM
by eliottiph
I'm reviving this thread because I haven't received an answer to my last question yet, so I can't deploy my custom package, which is essential for my core system.
Could I please get some help?
Thanks in advance,
Eliott.
Published: June 29, 2022 - 10:01 PM
by sfonteneau
eliottiph wrote: ↑May 10, 2022 - 3:53 PM On the other hand, the targeted machine installs the registry key only on its local master account.
This will be executed in all sessions at session startup thanks to session-setup
