Page 1 of 2
Issue using WinPE Usb Key\Bootsect.exe
Published: May 10, 2022 - 11:01
by juniormateus
Hi i have an issue when trying to prepare a USB key for boot
I'm able to change the keyboard language, then choose the diskpart, after that i get this error on this Link: http://snpy.in/VmvWpP
Follow by a message like the usb are ready !
Re: Issue using WinPE Usb Key\Bootsect.exe
Published: May 10, 2022 - 1:07 PM
by sfonteneau
Hello
Bootsect.exe is not present in system32
Are you on a windows 7? I thought it was on all windows 10
I will see to add Bootsect.exe to the minimal wads-requierement package
Published: May 10, 2022 - 2:39 PM
by juniormateus
sfonteneau wrote: ↑May 10, 2022 - 1:07 p.m. Hello
Hi,
Yes, it's on Windows 10 as well
Published: May 10, 2022 - 2:58 PM
by sfonteneau
You can try installing the tis-microsoft-adk package on your machine to see if it places this file?
Published: May 11, 2022 - 10:39
by juniormateus
sfonteneau wrote: ↑May 10, 2022 - 2:58 p.m. You can try installing the tis-microsoft-adk package on your machine to see if it places this file?
Hi trying to download the package, here is the error in the link bellow:
http://snpy.in/t5prcS
Published: May 11, 2022 - 11:39
by sfonteneau
I got the wrong package name, it's "tis-adkwinpe"
Published: May 11, 2022 - 12:13
by juniormateus
sfonteneau wrote: ↑May 11, 2022 - 11:39 I got the wrong package name, it's "tis-adkwinpe"
adkwinpe are already installed
http://snpy.in/qaVbXe
Published: May 11, 2022 - 1:51 PM
by sfonteneau
I just updated the tis-wads-requirement-minimal package
https://luti.tranquil.it/get_folder_res ... 93aW5kb3dz
it now includes the copy of the Bootsect.exe file if it is not present on your machine
you can duplicate the package from this repository: https://wapt.tranquil.it/wapt-testing/
Published: May 11, 2022 - 4:01 PM
by juniormateus
sfonteneau wrote: ↑May 11, 2022 - 1:51 p.m. I just updated the tis-wads-requirement-minimal package
Thank You let me tested, and I will let you know
Published: May 11, 2022 - 4:08 PM
by juniormateus
juniormateus wrote: ↑May 11, 2022 - 4:01 PM
I got this error, when try to duplicate
http://snpy.in/3Qlvvk
