Page 1 of 1
[RESOLVED] WAPT Discovery / Error in Windowsmoviemaker package
Published: May 13, 2022 - 08:42
by atricollege
When I try to push the "windows-moviemaker" package version 16.4.3528.331-11 I get an error during installation.
Here is the log result:
Installing wapt-windows-moviemaker(=16.4.3528.331-11)
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1833, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1233, in _run
raise Exception(_('Error during installation of {}: errors in packages {}').format(
Exception: Error during installation of ['wapt-windows-moviemaker(=16.4.3528.331-11)']: errors in packages [[PackageRequest(package='wapt-windows-moviemaker',version=(Version('16.4.3528.331'), 11),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-7', 'win-7', 'w-7', 'windows7', 'win7', 'w7', 'windows', 'win', 'w'],min_os_version=Version('6.1.7601.2'),max_os_version=Version('6.1.7601.2')), PackageEntry('wapt-windows-moviemaker','16.4.3528.331-11' maturity='PROD'), 'Traceback (most recent call last):\nFile "C:\\Program Files (x86)\\wapt\\common.py", line 5128, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4112, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3961, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1534, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source File "
Exception: Error installing ['wapt-windows-moviemaker(=16.4.3528.331-11)']: errors in packages [[PackageRequest(package='wapt-windows-moviemaker',version=(Version('16.4.3528.331'), 11),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-7', 'win-7', 'w-7', 'windows7', 'win7', 'w7', 'windows', 'win', 'w'],min_os_version=Version('6.1.7601.2'),max_os_version=Version('6.1.7601.2')), PackageEntry('wapt-windows-moviemaker','16.4.3528.331-11' maturity='PROD'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5128, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\wapt\common.py", line 4112, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3961, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\wapt\waptutils.py", line 1534, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "
self._run()
It seems to me that there is therefore a problem on line 16 of the setup.py file, but as I have never touched Python, I am quite unable to troubleshoot it.
Any ideas?
Thanks in advance !
Re: WAPT Discovery / Error in the Windowsmoviemaker package
Published: May 13, 2022 - 09:57
by sfonteneau
Re: [SOLVED] WAPT Discovery / Error in Windowsmoviemaker package
Published: May 16, 2022 - 2:10 PM
by atricollege
That's perfect, thank you! :mrgreen:
