Package creation and private key.
Libersa
Registration: May 26, 2015 - 3:09 p.m.
June 3, 2015 - 3:29 PM
I'm encountering another error with WAPT, this time with package creation.
When I run the commands, the command prompt displays the following errors:
For "wapt-get make-template":
"Warning: No private key provided, package [...].wapt is unsigned!"
For "wapt-get sign-package":
"Fatal error: exception: Private Key filename not set in private_key".
My local configuration correctly specifies the location of the private key for package signing, but this doesn't seem to be applied. Is there a configuration file I need to modify?
rezidu
Registration: March 16, 2015 - 10:21
June 5, 2015 - 09:35
I've had similar problems with the private key before.
I'm not entirely sure how to resolve it in the configuration files.
But try temporarily using "-k"
Libersa
June 5, 2015 - 1:08 PM
a colleague of mine found the solution:
Edit the wapt-get.ini file with Notepad++ and add the following line:
private_key=
Example:
private_key=C:\keyfolder\waptkey.pem
This solved our problem; I hope it will do the same for others.
Libersa.
