Page 1 of 2
selfservice portal
Published: June 22, 2022 - 10:43
by juniormateus
I'm going to share a problem we're having.
Here's what I configured: a self-service portal (Infra_Rep02) as follows:
I specified the AD group "INFRA_GG" to which the AD account mateus.junior belongs.
And on the self-service portal, I only defined a few packages for this self-service!
Here's a screenshot of the self-service configuration: http://snpy.in/Yu2ssu
Here's a screenshot of the AD group: http://snpy.in/U0AD2g
Here's a screenshot of the client machine: http://snpy.in/kuFToW
When I go to mateus.junior's client machine and access his self-service portal, I notice that he has all the packages, instead of just the limited packages as configured.
Here's a screenshot: http://snpy.in/1iOTzv
Re: SelfService Portal
Published: June 22, 2022 - 11:04 AM
by sfonteneau
Is the user an administrator on their machine? https://www.wapt.fr/fr/doc/wapt-usage-a ... lf-service
Is the user a member of a group named waptselfservice? https://www.wapt.fr/fr/doc/wapt-usage-a ... inistrator
Published: June 22, 2022 - 12:18
by juniormateus
sfonteneau wrote: ↑June 22, 2022 - 11:04 AM Is the user an administrator on their machine? https://www.wapt.fr/fr/doc/wapt-usage-a ... lf-service
Hello, yes, the user is also a local administrator of their machine
I just disabled the packages for local administrators, according to the tutorial
http://snpy.in/8O93Vl
I am modifying the wapt-get.ini file: http://snpy.in/dEJn7I
I'm creating a new group in Active Directory, including: waptselfservice: http://snpy.in/Py7cOY
I modified the selfservice which now points to the new waptselfservice group: http://snpy.in/6gQBU7
I updated the PC in the WAPT console, but unfortunately, I still see all the packages on the machine!
Published: June 22, 2022 - 12:23
by sfonteneau
I didn't quite understand you.
You should n't create a waptselfservice group (users who are members of this group can see all the packages).
Published: June 22, 2022 - 12:38
by juniormateus
sfonteneau wrote: ↑June 22, 2022 - 12:23 I didn't quite understand you.
OK, I just changed the group name to infraselfservice: http://snpy.in/9ew4dJ
I created a new infraselfservice group in the AD: http://snpy.in/KLEWtz
Published: June 22, 2022 - 12:39
by juniormateus
juniormateus wrote: ↑June 22, 2022 - 12:38
But the problem persists; this customer continues to see everything!
Published: June 22, 2022 - 1:04 PM
by sfonteneau
There's one last subtlety I forgot.
Is your user a member of domain admins?
Administrators can see all packages even with the waptservice_admin_filter condition.
Published: June 22, 2022 - 1:10 PM
by juniormateus
sfonteneau wrote: ↑June 22, 2022 - 1:04 PM There's one last subtlety I forgot.
Administrators can see all packages even despite the waptservice_admin_filter condition
I'm going to test that
Published: June 22, 2022 - 2:40 PM
by juniormateus
juniormateus wrote: ↑June 22, 2022 - 1:10 PM
Hi, I just tested it on a user who isn't a member of domain admins, and the problem is the same; they can see all the packages
Published: June 22, 2022 - 3:00 PM
by sfonteneau
I just noticed a small typo in the documentation:
the parameter is correct
and not
waptservice_admin_filtre
I'll correct
then restart the service
