Page 1 of 1
Change the %TEMP% of wapt
Published: July 8, 2022 - 11:44 AM
by t.heroult
Hello
, By default, WAPT extracts its packages to the system's TEMP directory (typically C:\Windows\temp) to launch installations.
Is it possible to configure WAPT to use a specific folder?
Regards,
Tom
Re: Changing the %TEMP% of wapt
Published: July 11, 2022 - 7:18 PM
by dcardon
Hello t.heroult,
It must be using the current user's %TEMP% directory, so in this case, LOCAL_SYSTEM. We're thinking of moving it to c:\ProgramData. Why is this causing you a problem?
Regards,
Published: August 5, 2022 - 11:18
by t.heroult
Hi Denis
, well, I have a few thin clients, machines with embedded Windows, configured to use a RAM drive to simulate a Z: drive as a temp folder.
However, this temp drive is only 80 MB, which quickly limits the size of the packages we want to install.
So, the idea is that I could tell WAPT: Don't use the default temp folder, which is terrible, but use the location I'm telling you about instead. :)
Published: August 24, 2022 - 5:22 PM
by dcardon
This isn't currently supported by the code; we'll look internally to see if we can add a parameter to specify a different directory.
Regards,
Published: August 26, 2022 - 11:48
by t.heroult
Thanks, that would be great!
Best regards,
Tom
Published: August 30, 2022 - 11:54
by Christophe0110
This parameter interests me a lot too!
