Page 1 of 1
[RESOLVED] Buffer error
Published: July 18, 2022 - 10:46 AM
by smandel
Following the deployment of WAPT across our entire network, we have noticed that many workstations are experiencing an error when logging in:
Le système a détecté la saturation de la mémoire tampon dans cette application.
Cette saturation pourrait permettre à un utilisateur mal intentionné de prendre le contrôle de cette application
In some cases it only appears once, in others it is impossible to open a session with a black screen.
Should we increase the virtual memory of workstations?
Today this parameter is managed by the system.
THANKS.
Re: Buffer error
Published: July 18, 2022 - 6:35 PM
by dcardon
this is the first time I've seen this error in a wapt context. What RAM/pagefile.sys size do the machines in question have?
Re: Buffer error
Published: July 19, 2022 - 1:52 PM
by smandel
virtual memory is managed by the system.
All PCs have a minimum of 4GB of RAM and are primarily used for office work.
Thank you.
Re: Buffer error
Published: July 19, 2022 - 2:13 PM
by dcardon
Do you have anything in the Event Viewer related to this? It would be helpful to know which executable generated this message.
Regards,
Re: Buffer error
Published: July 19, 2022 - 3:57 PM
by smandel
That's all I have in the events:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Popup" Guid="{47bfa2b7-bd54-4fac-b70b-29021084ca8f}" />
<EventID>26</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2022-07-18T06:41:07.6154840Z" />
<EventRecordID>15566</EventRecordID>
<Correlation />
<Execution ProcessID="1192" ThreadID="1208" />
<Channel>System</Channel>
<Computer>XXXXXXXX</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="Caption">dllhost.exe - Erreur système</Data>
<Data Name="Message">Le système a détecté la saturation de la mémoire tampon dans cette application. Cette saturation pourrait permettre à un utilisateur mal intentionné de prendre le contrôle de cette application.</Data>
</EventData>
</Event>
Re: Buffer error
Published: July 19, 2022 - 4:46 PM
by dcardon
The WAPT agent isn't launching dllhost.exe, so it's not directly related to WAPT; it might be a side effect, but this is the first time we've heard of it. Could you try Windows troubleshooting tools like sfc /scannow or something similar?
Regards,
Re: Buffer error
Published: July 20, 2022 - 09:43
by smandel
I've already tried it on the affected machines without encountering any errors.
But the problem seems to occur only on Windows 11, and the message only appears once...
The message no longer appears on the machines that had the problem.
Something to keep an eye on.
Thanks anyway.
Re: Buffer error
Published: July 20, 2022 - 2:13 PM
by dcardon
Okay, thanks for the feedback, I'm marking the issue as resolved.
