[SOLVED] Pb Acrobat Reader DC Package
Published: September 22, 2022 - 3:57 PM
I've noticed that since the latest version of the Acrobat Reader DC package, on all my PCs equipped with the Acrobat Pro DC version (managed with Creative Cloud), I get the following error:
On PCs that do not have the Pro version of Acrobat DC, I have no installation problems.
Do you have any idea where the problem might be coming from?
- WAPT Enterprise 2.2.1.11957
- Agent version: 2.2.1.11957
- Server OS (Windows Server 2022)
- OS administration (Windows 10)
installation Adobe Reader MUI
File "C:\Program Files (x86)\wapt\common.py", line 4035, in install_wapt
File "C:\windows\TEMP\wapt1xh99cy_\setup.py", line 38, in install
File "C:\Program Files (x86)\wapt\common.py", line 3817, in run
File "C:\Program Files (x86)\wapt\waptutils.py", line 2126, in run
waptutils.CalledProcessErrorOutput: Command '"AcroRdrDCx642200220191_MUI.exe" /sAll /msi /norestart /quiet ALLUSERS=1 EULA_ACCEPT=YES UPDATE_MODE=0 DISABLE_ARM_SERVICE_INSTALL=1 DISABLEDESKTOPSHORTCUT=1' returned non-zero exit status 1603.
Output:
Output:Do you have any idea where the problem might be coming from?
