Samba AD does not create the reverse zone
Published: September 29, 2022 - 2:32 PM
Hello everyone,
I'm testing Samba AD and I'm having trouble with the DNS part. I'm using your tutorial: https://samba.tranquil.it/doc/fr/samba_ ... ebian.html
Everything is fine; I can add and remove hosts from my zone, but I realize that the reverse DNS record for this zone hasn't been created. So I create it via the MMC DNS from a Windows machine. Everything is OK, and I add a new A host (toto with IP address 192.168.1.31) to my zone by checking the "Create an associated PTR record pointer" box. I confirm the creation and go to "Reverse Lookup Zones" > 1.168.192.in-addr.arp.arpa, but there's no trace of toto's reverse DNS record.
I can create it manually, but since I was planning to set up DHCP with dynamic DNS updates, it seems necessary that the reverse DNS records update correctly.
Is there a specific configuration?
Thanks in advance.
Philippe.
# samba-tool dns zonelist svdom01
Password for [DOMAIN\root]:
3 zone(s) found
pszZoneName : 1.168.192.in-addr.arpa
Flags : DNS_RPC_ZONE_DSINTEGRATED DNS_RPC_ZONE_UPDATE_SECURE
ZoneType : DNS_ZONE_TYPE_PRIMARY
Version : 50
dwDpFlags : DNS_DP_AUTOCREATED DNS_DP_DOMAIN_DEFAULT DNS_DP_ENLISTED
pszDpFqdn : DomainDnsZones.domaine.fr
pszZoneName : domaine.fr
Version : 50
pszZoneName : _msdcs.domaine.fr
Version : 50
dwDpFlags : DNS_DP_AUTOCREATED DNS_DP_FOREST_DEFAULT DNS_DP_ENLISTED
pszDpFqdn : ForestDnsZones.domaine.frThanks in advance.
Philippe.
