Page 1 of 1
[RESOLVED] Secondary repository
Published: September 30, 2022 - 10:21
by Geoffroy
Wapt Enterprise 2.2.3 Windows Active Directory environment.
I'm having a problem with my secondary repositories. We have three sites: one primary and two remote.
On the primary site, there's the console and server;
on the secondary sites, there are the repositories.
The rules are working, and the workstations are correctly placed in the right location.
The problem we're encountering is that we have to put the packages in the root of the OU for them to be installed on the workstations.
This means we can't install them on a case-by-case basis.
Is this normal, or is there a problem somewhere?
Thank you for your feedback.
Re: Secondary Depot
Published: October 3, 2022 - 10:38 AM
by sfonteneau
Good morning
Sorry, I didn't quite understand the issue.
Bous sommes obligés de mettre les pacquet à la racine de l'OU pour que celui soit installé sur les postes.
Do you mean that only the OR configurations work?
Re: Secondary Depot
Published: October 3, 2022 - 12:23
by dcardon
Do you synchronize packets between machines at remote sites? Do the workstations see the packets on the server, or only the repository?
Regards,
Re: Secondary Depot
Published: October 3, 2022 - 6:48 PM
by Geoffroy
Problem solved; we just had to wait for replication to occur between the remote repositories
