Page 1 of 1
[RESOLVED] Wapt Self-Service network change
Published: October 7, 2022 - 11:25 AM
by walibix
I'm currently using wapt-entreprise and I'm having trouble with the self-service portal for my remote users.
When they're in the office, it works perfectly (first point ;p).
Then,
when they leave, go home, and turn on the VPN, it fails (it tells them the password is incorrect).
I take control of their computer
, restart the waptservice, and it works again.
How can I bypass/fix this issue? And/or what's causing this authentication problem?
Thanks in advance
. Best regards.
Re: Wapt Self-Service network change
Published: October 7, 2022 - 4:33 PM
by sfonteneau
Good morning
Sometimes it's a "krbtgt" issue on the local machine regarding remote work
The ideal solution would be to switch the service to waptserver-ldap mode
C:\Program Files (x86)\wapt\wapt-get.ini
[global]
service_auth_type=waptserver-ldap
This limits the problems since the WAPT server handles the authentication, not the local machine
On the server side, however, LDAP must be configured:
https://www.wapt.fr/fr/doc/wapt-securit ... entication
And if you are using Kerberso, you must also configure the following:
https://www.wapt.fr/en/doc/wapt-securit ... le-sign-on
Published: October 10, 2022 - 4:03 PM
by walibix
Thank you for this feedback
Yes, I am using Kerberos authentication
To be "sure" of not making a mistake, I "simply" need to add:
wapt_admin_group_dn=CN=waptadmins,OU=groups,OU=tranquilit,DC=mydomain,DC=lan
ldap_auth_server=srvads.mydomain.lan
ldap_auth_base_dn=DC=mydomain,DC=lan
ldap_auth_ssl_enabled=False
of course adapted to my domain (AD), and I modify the file on each client:
[global]
Will this have any impact on machines that currently authenticate using Kerberos? (Will both be accepted?)
THANKS
Sincerely
Published: October 10, 2022 - 4:35 PM
by dcardon
Hello Walibix,
yes, it should test Kerberos auth, and fall back to login/password auth if Kerberos auth is not available (i.e. the domain controller is not accessible).
Published: October 10, 2022 - 6:23 PM
by sfonteneau
For Kerberos, you will need to add an additional service account:
ldap_account_service_login = wapt-ldap@ad.tranquil.it
ldap_account_service_password = PASSWORD
So that the server can parse the groups from the AD
