[SOLVED] Adding user to local group
Published: November 9, 2022 - 12:13 PM
I am having trouble with a command to add the user to a Local group in auditing.
I'm encountering an error when the user is already in the group; they don't meet the first condition, and it's trying to add them. Hence the error
Here is the relevant snippet of script:
Thank you
2022-11-08 09:44:33,484 CRITICAL Fatal error in audit function: TypeError: 'error' object is not subscriptable:
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 2264, in add_user_to_group
win32net.NetLocalGroupAddMembers(None, group, 3, [user_group_info])
pywintypes.error: (1378, 'NetLocalGroupAddMembers', 'Le nom de compte spécifié est déjà membre du groupe.')
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2978, in call_setup_hook
hookdata = hook_func()
File "C:\waptdev\futur-Creation_Profil_2.0-60_windows_PREPROD-wapt\setup.py", line 79, in audit
add_user_to_group(user, "Utilisateurs avec pouvoir")
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 2267, in add_user_to_group
if e[0] != 1378:
Audit aborted due to exception: 'error' object is not subscriptableHere is the relevant snippet of script:
user = registry_readstring(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion\Authentication\LogonUI", "LastLoggedOnUser")
if user in local_group_members("Utilisateurs avec pouvoir"):
print("Utilisateur déjà dans le groupe Utilisateurs avec pouvoir")
elif user not in local_group_members("Utilisateurs avec pouvoir"):
print("Utilisateurs pas de le groupe Power Users")
