Page 1 of 1
[RESOLVED] OS Deployment
Published: November 9, 2022 - 5:09 PM
by dj41ph4
I've set up several PCs and they all work (Lenovo, HP, Dell).
I have a Lenovo with an Intel processor that refuses to start the deployment. Everything works until I launch diskpart...
basically, Diskpart doesn't see the hard drive and therefore stops.
The PC itself works. I noticed that the SSD is BitLocker (I don't know if that's relevant).
I tried installing SCCM drivers for the model, but nothing changed.
Do you have any ideas?
Thanks in advance.
Re: OS Deployment
Published: November 9, 2022 - 5:33 PM
by dcardon
Hello dj41ph4,
could you please check in the BIOS whether the disk is configured in RAID mode or basic SSD mode?
Regards,
Re: OS Deployment
Published: November 10, 2022 - 12:50 AM
by dj41ph4
In normal
BIOS UEFI basic mode with secure boot disabled.
Best regards
Re: OS Deployment
Published: November 10, 2022 - 8:43 AM
by dj41ph4
The problem stems from the Intel Volume Management Device, which needs to be disabled in the BIOS...
have you encountered this issue before?
Thanks
Re: [RESOLVED] OS Deployment
Published: November 10, 2022 - 09:32
by dcardon
Hello dj41ph4,
we've seen several cases where the BIOS was configured at the SSD level in RAID mode or some other unusual manufacturer configuration. This can be supported, but you need to load the correct drivers in WinPE. The easiest solution is to modify the BIOS settings.
It's not common, but it's not extremely rare either.
Regards,
Published: November 10, 2022 - 11:01 AM
by dj41ph4
dcardon wrote: ↑Nov 10, 2022 - 9:32 AM Hello dj41ph4,
we've seen several cases of BIOSes configured at the SSD level in RAID mode or some other strange manufacturer configuration. It might be supported, but you need to load the correct drivers in WinPE. The easiest way is to modify the BIOS settings.
Regards,
To load drivers into WinPE, is it directly in the "driver" tab of the WAPT console? Because I don't think adding the Intel RST drivers changes anything...
Published: November 10, 2022 - 11:50 AM
by dcardon
please start a new thread for a new question (otherwise it complicates the moderation team's job).
Regards,
