Page 1 of 1
[RESOLVED] Console Closure
Published: November 10, 2022 - 09:25
by haxo_914
I'm contacting you again because the issue of the console closing 10 seconds after opening the private repositories has reappeared.
I hadn't experienced this problem since May and the application of a patch.
My configuration has changed slightly:
PC Windows 11 21 H2 22000.1098,
WAPT Server version: 2.2.1 Enterprise - CentOS 7,
Console: 2.2.1.11899
, Proxy Server.
Have you encountered this problem again?
Thank you.
Re: Console Closure
Published: November 10, 2022 - 10:33 AM
by bkolovljanovic
We did indeed encounter this issue. It was fixed in subsequent versions (still in 2.2.1).
viewtopic.php?p=10130#p10130
I encourage you to update to the latest version 2.2.1 if you wish to remain on 2.2.1
https://www.wapt.fr/fr/doc/wapt-changel ... 2022-06-02
Re: [SOLVED] Console Closure
Published: November 10, 2022 - 12:31
by haxo_914
I just restarted the server and then the console, and the problem is solved.
Thank you.
Published: November 10, 2022 - 2:33 PM
by dcardon
Hello Haxo_914,
thank you for your feedback, glad it's resolved :-)
. Best regards,
