Crouzet-Soft package problem
Published: November 30, 2022 - 11:11 AM
I have a problem with a Crouzet Soft 1.12 package. The 'USB driver installation' part seems to go well and the software is installed on the machines, but the "Device Driver Installation Wizard" window appears and waits for a click on next, so the package ends with an error after 300s.
EDIT: My problem seems to be solved, but I don't know exactly what worked in my latest changes... In any case, if anyone needs this package, here's the setup.py file. The "DriverUSB" folder was copied from the software's installation folder.
app_name = 'Crouzet-Soft'
app_dir = makepath(programfiles32, 'Crouzet automation')
app_dir_binaries = makepath(app_dir,'Crouzet-Soft')
binary_name = "Crouzet-Soft.exe"
kill_list = [binary_name]
shortcutsdir = makepath(common_desktop(),'Logiciels','Elec - Automatisme')
uninstall_string = r'"C:\Program Files (x86)\Crouzet automation\Crouzet-Soft\unins000.exe" /silent'
print(r'Désinstallation de l\'ancienne version')
versionsoft = control['version'].split('-',1)[0]
softname = 'Crouzet-Soft'
check_installed_soft = installed_softwares(softname)
if check_installed_soft:
run(cmd)
print(r'Installation des pilotes USB')
currentpath = os.path.dirname(os.path.realpath(__file__))
##run_notfatal(r'%s\drivers\dpinst.exe /SW /F' % currentpath)
with disable_file_system_redirection():
run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a "%s\DriverUSB\x64\ftdibus.inf"' % basedir)
run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a "%s\DriverUSB\x64\ftdiport.inf"' % basedir)
run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a "%s\DriverUSB\windrv_BLE\x64\dfu.inf"' % basedir)
run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a "%s\DriverUSB\windrv_BLE\x64\usbserial.inf"' % basedir)
print(u'Installation de %s' % app_name)
install_exe_if_needed('Setup_CrouzetSoft_1.12.02.07.exe',
silentflags='/SILENT /VERYSILENT /SUPPRESSMSGBOXES /NORESTART',
key='6BCD8694-FAB1-406E-83E4-263BAAD2B163_is1',
min_version=' '
print(r'Creation du raccourci %s sur le bureau public' %app_name)
if not isdir(shortcutsdir):
mkdirs(shortcutsdir)
create_shortcut(makepath(shortcutsdir,'%s.lnk' %app_name), target=makepath(app_dir_binaries,binary_name))
remove_desktop_shortcut(app_name)
print(r"Desinstallation de %s" %app_name)
run_notfatal(r'%s' % uninstall_string)
if isfile(makepath(shortcutsdir,'%s.lnk' %app_name)):
remove_file(makepath(shortcutsdir,'%s.lnk' %app_name))
def audit():
if isfile(makepath(app_dir_binaries,binary_name)):
return("OK")
