Page 1 of 1
[RESOLVED] Console bug following update 2.2.3.12481: Invalid PPyObject
Published: Dec 2, 2022 - 9:28 AM
by t.heroult
Good morning
After updating the agent on my machine (Windows 11 Pro), I get an error message when:
- If I try to open a host to edit it (double click or menu or CTRL-O)
- If I try to "Edit the package in the editor"
- I'm launching an update-package
- I'm importing a package as a file
It doesn't happen on all machines, for now it's only mine.
I have of course uninstalled/reinstalled the agent.
Everything else seems OK
Here is the message:
Invalid PPyObject.png (7.38 KB) Viewed 2950 times
In the case of the update-package, the window opens to check for a new version, but when I try to run the check, I get this message along with another one:
module not found.png (5.67 KB) Viewed 2946 times
There is nothing in the WAPT logs.
Any ideas?
Tom
Re: Console bug following update 2.2.3.12481: Invalid PPyObject
Published: Dec 2, 2022 - 11:18
by t.heroult
After several attempts to reinstall the agent, the problem disappeared.
I'm leaving this here, in case it's helpful. :)
