Page 1 of 1
List of USER keys "S-1-5-21..." how to do it
Published: Dec 12, 2022 - 10:09
by Information Service
Hello everyone,
I'm trying to get the USER keys "S-1-5-21..." in 'HKEY_USERS' but I don't see how to do it.
Can you guide me?
Re: List of USER keys "S-1-5-21..." how to do it
Published: Dec 12, 2022 - 10:17
The goal is to manage user session locking and more
Published: Dec 12, 2022 - 11:29
Okay, I've found everything. If you see any improvements, I'm all ears
from setuphelpers_windows import *
veille="600"
    print("creation du tableau utilisateurs")
    cles = run_powershell("reg query HKEY_USERS")
    print("creation du tableau utilisateur OK")
    print("traitement des lignes")
    for i in cles:
        if len(i) == 57:
            racine = i[0:10]
            user = i[11:57]
            print("user traité "+user)
            if racine == "HKEY_USERS":
                print("modification des clés de registre")
                registry_setstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveActive", "1", type=REG_SZ)
                registry_setstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaverIsSecure", "1", type=REG_SZ)
                registry_setstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveTimeOut", veille, type=REG_SZ)
                registry_setstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "SCRNSAVE.EXE", "C:\WINDOWS\system32\scrnsave.scr", type=REG_SZ)
    registry_setstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveActive", "1", type=REG_SZ)
    registry_setstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaverIsSecure", "1", type=REG_SZ)
    registry_setstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveTimeOut", veille, type=REG_SZ)
    registry_setstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "SCRNSAVE.EXE", "C:\WINDOWS\system32\scrnsave.scr", type=REG_SZ)
Published: Dec 12, 2022 - 2:39 PM
Correction made to user search
veille="600"
    print(cles)
    for i in cles:
        i2 = i.split("\\")
        print("tableau split")
        print(i2)
        print("-----verification des variables")
        racine=i2[0]
        if racine != '':
            if "_Classes" not in i:
                user=i2[1]
                print(racine)
                print(user)
                if len(user) > 10:
                        print(r"Fin du traitement de l'utilisateur "+user)
    print("Fin des modifications utilisateurs")
    print("Modification des valeurs default user")
    print("Fin des modification des valeurs default user")
def audit():
    auditverif="OK"
    msgerror=[]
    #Vérification des différentes clés
    for i in cles:
        i2 = i.split("\\")
        print(i2)
        racine=i2[0]
        if racine != '':
                user=i2[1]
                print(racine)
                print(user)
                if len(user) > 10:
                        if(registry_readstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveActive"))!="1":auditverif="ERROR" and msgerror.append(user+" ScreenSaveActive")
                        if(registry_readstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaverIsSecure"))!="1":auditverif="ERROR" and msgerror.append(user+" ScreenSaverIsSecure")
                        if(registry_readstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveTimeOut"))!=veille:auditverif="ERROR" and msgerror.append(user+" ScreenSaveTimeOut")
                        if(registry_readstring(HKEY_USERS, r''+user+'\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "SCRNSAVE.EXE"))!="C:\WINDOWS\system32\scrnsave.scr":auditverif="ERROR" and msgerror.append(user+" SCRNSAVE.EXE")
    if(registry_readstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveActive"))!="1":auditverif="ERROR" and msgerror.append(user+" ScreenSaveActive")
    if(registry_readstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaverIsSecure"))!="1":auditverif="ERROR" and msgerror.append(user+" ScreenSaverIsSecure")
    if(registry_readstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "ScreenSaveTimeOut"))!=veille:auditverif="ERROR" and msgerror.append(user+" ScreenSaveTimeOut")
    if(registry_readstring(HKEY_USERS, r'.DEFAULT\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Desktop', "SCRNSAVE.EXE"))!="C:\WINDOWS\system32\scrnsave.scr":auditverif="ERROR" and msgerror.append(user+" SCRNSAVE.EXE")
    print(auditverif)
    print(msgerror)
    print("renvoi du résultat d'audit")
    if auditverif=="OK":return "OK"
    if auditverif=="ERROR":return "ERROR"
Published: Dec 13, 2022 - 11:14
by t.heroult
At one point, I wanted to use a script of this kind to modify individual settings of the Windows storage assistant.
It looked like this:
    HKUSERS =winreg.OpenKey( winreg.HKEY_USERS, '',0, winreg.KEY_READ)
    subKeys = winreg.QueryInfoKey(HKUSERS)
    nbSubkeys = subKeys[0]
    i = 0
    while i < nbSubkeys:
        #Modifications appliquées à tous les utilisateurs
        subKey = winreg.EnumKey(HKUSERS,i)
        if (subKey != ".DEFAULT"):
            #Reglage OneDrive
            key = winreg.CreateKey( winreg.HKEY_USERS, subKey + '\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\StorageSense\\Parameters\\StoragePolicy')
            winreg.SetValueEx(key, '01', 0, winreg.REG_DWORD, 1)
            winreg.SetValueEx(key, '04', 0, winreg.REG_DWORD, 1)
            winreg.SetValueEx(key, '256', 0, winreg.REG_DWORD, 30)
            winreg.SetValueEx(key, '512', 0, winreg.REG_DWORD, 60)
            winreg.SetValueEx(key, '2048', 0, winreg.REG_DWORD, 1)
            winreg.CloseKey(key)
        i += 1
Published: Dec 13, 2022 - 12:03 PM
Thanks for the feedback.
So, if you don't do it that way, what do you use?
Published: Dec 13, 2022 - 12:41
by t.heroult
I chose to use session-setup. This way, when a user logs in after the package has been installed, the settings are instantly applied to their profile.
Furthermore, this will also apply to future users.
