Page 1 of 1
[WAPT] Release WAPT 2.3
Published: January 10, 2023 - 5:01 PM
by Nina_M
Here is the new WAPT 2.3 release!
This new version does not bring any major new features, but many small fixes and improvements that make using WAPT even easier and more enjoyable.
What's new ?
  • Over 1000 minor fixes and improvements for a better user experience
  • Fewer false positives from antivirus software during WAPTAgent deployment
  • improved robustness of Websockets, improved reliability of connected statuses
  • improved WAPT support under Linux (and WAPT Console under Linux in Tech Preview)
  • improved WAPT support under macOS (and WAPT Console under macOS in Tech Preview)
Changelog: https://doc.wapt.fr/wapt-changelog.html
Updated 20/01/23
Release bugfix for WAPT 2.3, it mainly consists of fixes and improvements aimed at facilitating the process of upgrading from older versions of WAPT.
If you have not yet upgraded to WAPT 2.3, you can update directly to this new version.
If you have no issues with the current version 2.3, the update is not necessary.
Changelog: https://doc.ad.tranquil.it/wapt/fr/doc- ... 2023-01-19
Updated 26/01/23
Support is available for Red Hat Enterprise Linux version 9
Minor release of bug fixes
Changelog: https://www.wapt.fr/en/doc/wapt-changel ... 2023-01-26
Updated 23/02/23
New WAPT release 2.3.0.13516. This version mainly contains bug fixes related to updates in certain specific cases.
Changelog: https://www.wapt.fr/fr/doc/wapt-changel ... gelog.html
Update 20/01/23
Those are mainly fixes and improvements to smooth the upgrade process from older WAPT versions.
If you have not upgraded to WAPT 2.3, you can upgrade directly to this new version.
If you have no problems with the current version 2.3, the update is not necessary.
Update 26/01/23
Minor bugfix release
Add support for Red Hat Enterprise Linux 9
Update 23/02/23
New release WAPT 2.3.0.13516. This version contains mainly bug fixes for updates in some specific cases.
Changelog: [url]https://www.wapt.fr/fr/doc/wapt-changelog.html[url]
